February 20, 2023 at 10:09 am
djihad-amina.djemmah
SubscriberHello, I have a question regarding the display of results. I am using the grating S-parameters for my 3D simulations with 2000 frequency points, and my frequency range is from 200 to 400 GHz.
The simulation takes a few hours, but after it finishes, the display of the results (S-parameters) also takes a few hours. Is this normal? Do you know why this might be happening?
Thank you in advance
February 21, 2023 at 9:26 am
Greg Baethge
Ansys EmployeeHi Amina,
Thank you for posting your question on the forum. The main issue here is the number of frequency points: the grating S-parameter analysis group calculates the S parameters at each frequency, sequentially (basically, using a for loop in the analysis script), so with 2000 points, the loop takes some time!
The first question would be whether you need that many point? Is that the case?
- The topic ‘grating S-parameters’ is closed to new replies.
4613
1520
1386
1209
