February 24, 2023 at 12:01 pm
lisa.lust
SubscriberHere is the output of the test
C:UsersE731679>"C:Program FilesANSYS Incv231FrameworkbinWin64Ans.DriverSetup.exe" --check-system-compatibility
OPENGL_VERSION Â = 4.6.0 NVIDIA 452.66
OPENGL_VENDOR Â = NVIDIA Corporation
OPENGL_RENDERER = Quadro P3000/PCIe/SSE2
OPENGL_EXTENSIONS = WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_no_error WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_context_flush_control WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_colorspace WGL_EXT_create_context_es_profile WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_EXT_swap_control_tear WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_copy_image WGL_NV_delay_before_swap WGL_NV_float_buffer WGL_NV_gpu_affinity WGL_NV_multisample_coverage WGL_NV_multigpu_context WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle WGL_NV_swap_group
    found: WGL_NV_DX_interop2
    found: wglDXOpenDeviceNV
Found OpenCL Platforms:Â Â Â Â Name[Intel(R) OpenCL HD Graphics]
    Profile[1]
    Vendor[Intel(R) Corporation]
    Version[3.0.0 [ ]]
    Extensions[
        cl_khr_byte_addressable_store
        , cl_khr_fp16
        , cl_khr_global_int32_base_atomics
        , cl_khr_global_int32_extended_atomics
        , cl_khr_icd
        , cl_khr_local_int32_base_atomics
        , cl_khr_local_int32_extended_atomics
        , cl_intel_subgroups
        , cl_intel_required_subgroup_size
        , cl_intel_subgroups_short
        , cl_khr_spir
        , cl_intel_accelerator
        , cl_intel_driver_diagnostics
        , cl_khr_priority_hints
        , cl_khr_throttle_hints
        , cl_khr_create_command_queue
        , cl_intel_subgroups_char
        , cl_intel_subgroups_long
        , cl_khr_il_program
        , cl_intel_mem_force_host_memory
        , cl_khr_subgroup_extended_types
        , cl_khr_subgroup_non_uniform_vote
        , cl_khr_subgroup_ballot
        , cl_khr_subgroup_non_uniform_arithmetic
        , cl_khr_subgroup_shuffle
        , cl_khr_subgroup_shuffle_relative
        , cl_khr_subgroup_clustered_reduce
        , cl_khr_fp64
        , cl_khr_subgroups
        , cl_intel_spirv_device_side_avc_motion_estimation
        , cl_intel_spirv_media_block_io
        , cl_intel_spirv_subgroups
        , cl_khr_spirv_no_integer_wrap_decoration
        , cl_intel_unified_shared_memory_preview
        , cl_khr_mipmap_image
        , cl_khr_mipmap_image_writes
        , cl_intel_planar_yuv
        , cl_intel_packed_yuv
        , cl_intel_motion_estimation
        , cl_intel_device_side_avc_motion_estimation
        , cl_intel_advanced_motion_estimation
        , cl_khr_int64_base_atomics
        , cl_khr_int64_extended_atomics
        , cl_khr_image2d_from_buffer
        , cl_khr_depth_images
        , cl_khr_3d_image_writes
        , cl_intel_media_block_io
        , cl_khr_gl_sharing
        , cl_khr_gl_depth_images
        , cl_khr_gl_event
        , cl_khr_gl_msaa_sharing
        , cl_intel_dx9_media_sharing
        , cl_khr_dx9_media_sharing
        , cl_khr_d3d10_sharing
        , cl_khr_d3d11_sharing
        , cl_intel_d3d11_nv12_media_sharing
        , cl_intel_unified_sharing
        , cl_intel_simultaneous_sharing
    ]    Name[NVIDIA CUDA]
    Profile[1]
    Vendor[NVIDIA Corporation]
    Version[1.2.0 [ CUDA 11.0.228]]
    Extensions[
        , cl_khr_fp64
        , cl_khr_byte_addressable_store
        , cl_khr_icd
        , cl_khr_gl_sharing
        , cl_nv_compiler_options
        , cl_nv_device_attribute_query
        , cl_nv_pragma_unroll
        , cl_nv_d3d10_sharing
        , cl_nv_d3d11_sharing
        , cl_nv_copy_opts
        , cl_khr_gl_event
        , cl_nv_create_buffer
        , cl_kernel_attribute_nv
[2 Â Â Â ][dbgerr][19828] AssertFailedException: "NVAPI_OK == p_status" - void __cdecl `anonymous-namespace'::CheckStatus::Check(const enum _NvAPI_Status,int)
At:
    [0]00007FF62DD2F1FE        (0)
    [1]00007FF62DD30301        (0)
    [2]00007FF62DD29062        (0)
    [3]00007FF62DD2CCF8        (0)
    [4]00007FF62DD25E1F        (0)
    [5]00007FF62DD1183C        (0)
    [6]00007FF62DD13728        (0)
    [7]00007FF62DD430F0        (0)
    [8]00007FFA99FB7614   BaseThreadInitThunk    (0)
    [9]00007FFA9ADC26A1   RtlUserThreadStart    (0)Failed to add/update profile.
NVidia driver installation found.
Driver: 45266
Branch: r450_00Found an existing profile: Ansys Workbench Products
settings:
Enable application for Optimus(0x10f9dc81) = 1
Shim Rendering Mode Options per application for Optimus(0x10f9dc84) = 0
Optimus flags for enabled applications(0x10f9dc80) = 1
applications:Found an existing profile: Ansys ACP
settings:
(0x20335bca) = 0
Error occurred during profile update.
exception: AssertFailedException: "NVAPI_OK == p_status" - void __cdecl `anonymous-namespace'::CheckStatus::Check(const enum _NvAPI_Status,int)
***************************************************************************************************** ERRORS *********************
[1 Â Â Â ][dbgerr][19828] NVAPI call failed with: NVAPI_INVALID_USER_PRIVILEGE @269
[3 Â Â Â ][dbgerr][19828] NVAPI: Failed to check profile.
AssertFailedException: "NVAPI_OK == p_status" - void __cdecl `anonymous-namespace'::CheckStatus::Check(const enum _NvAPI_Status,int) -
February 26, 2023 at 11:54 pm
Devendra Badgujar
Forum ModeratorHello Dr. Lisa Lust
Continued in Graphics Card Discovery EMA 3d Install - Questions - Ansys Discovery Forum
- The topic ‘Graphics Issue with Discovery Install’ is closed to new replies.
5934
1306
