3D Design
3D Design
Graphics Card Discovery EMA 3d Install
    • lisa.lust
      I received graphics errors in the install.
      It also would not install MS QSP.NET Hosting Bundle 6.0.8
      I have two cards
      Intel HD Graphics 630 on the laptop
      NVIDIA Quadro P3000 on the monitor.
      Please help me with the install. I believe my desk monitor is sufficient.
      I ran
      C:UsersE731679>"C:Program FilesANSYS Incv231FrameworkbinWin64Ans.DriverSetup.exe" --check-system-compatibility
      OPENGL_VERSION  = 4.6.0 NVIDIA 452.66
      OPENGL_VENDOR   = NVIDIA Corporation
      OPENGL_RENDERER = Quadro P3000/PCIe/SSE2
      OPENGL_EXTENSIONS = WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_no_error WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_context_flush_control WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_colorspace WGL_EXT_create_context_es_profile WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_EXT_swap_control_tear WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_copy_image WGL_NV_delay_before_swap WGL_NV_float_buffer WGL_NV_gpu_affinity WGL_NV_multisample_coverage WGL_NV_multigpu_context WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle WGL_NV_swap_group
              found: WGL_NV_DX_interop2
              found: wglDXOpenDeviceNV
      Found OpenCL Platforms:
              Name[Intel(R) OpenCL HD Graphics]
              Profile[1]
              Vendor[Intel(R) Corporation]
              Version[3.0.0 [ ]]
              Extensions[
                      cl_khr_byte_addressable_store
                      , cl_khr_fp16
                      , cl_khr_global_int32_base_atomics
                      , cl_khr_global_int32_extended_atomics
                      , cl_khr_icd
                      , cl_khr_local_int32_base_atomics
                      , cl_khr_local_int32_extended_atomics
                      , cl_intel_subgroups
                      , cl_intel_required_subgroup_size
                      , cl_intel_subgroups_short
                      , cl_khr_spir
                      , cl_intel_accelerator
                      , cl_intel_driver_diagnostics
                      , cl_khr_priority_hints
                      , cl_khr_throttle_hints
                      , cl_khr_create_command_queue
                      , cl_intel_subgroups_char
                      , cl_intel_subgroups_long
                      , cl_khr_il_program
                      , cl_intel_mem_force_host_memory
                      , cl_khr_subgroup_extended_types
                      , cl_khr_subgroup_non_uniform_vote
                      , cl_khr_subgroup_ballot
                      , cl_khr_subgroup_non_uniform_arithmetic
                      , cl_khr_subgroup_shuffle
                      , cl_khr_subgroup_shuffle_relative
                      , cl_khr_subgroup_clustered_reduce
                      , cl_khr_fp64
                      , cl_khr_subgroups
                      , cl_intel_spirv_device_side_avc_motion_estimation
                      , cl_intel_spirv_media_block_io
                      , cl_intel_spirv_subgroups
                      , cl_khr_spirv_no_integer_wrap_decoration
                      , cl_intel_unified_shared_memory_preview
                      , cl_khr_mipmap_image
                      , cl_khr_mipmap_image_writes
                      , cl_intel_planar_yuv
                      , cl_intel_packed_yuv
                      , cl_intel_motion_estimation
                      , cl_intel_device_side_avc_motion_estimation
                      , cl_intel_advanced_motion_estimation
                      , cl_khr_int64_base_atomics
                      , cl_khr_int64_extended_atomics
                      , cl_khr_image2d_from_buffer
                      , cl_khr_depth_images
                      , cl_khr_3d_image_writes
                      , cl_intel_media_block_io
                      , cl_khr_gl_sharing
                      , cl_khr_gl_depth_images
                      , cl_khr_gl_event
                      , cl_khr_gl_msaa_sharing
                      , cl_intel_dx9_media_sharing
                      , cl_khr_dx9_media_sharing
                      , cl_khr_d3d10_sharing
                      , cl_khr_d3d11_sharing
                      , cl_intel_d3d11_nv12_media_sharing
                      , cl_intel_unified_sharing
                      , cl_intel_simultaneous_sharing
              Name[NVIDIA CUDA]
              Profile[1]
              Vendor[NVIDIA Corporation]
              Version[1.2.0 [ CUDA 11.0.228]]
              Extensions[
                      , cl_khr_fp64
                      , cl_khr_byte_addressable_store
                      , cl_khr_icd
                      , cl_khr_gl_sharing
                      , cl_nv_compiler_options
                      , cl_nv_device_attribute_query
                      , cl_nv_pragma_unroll
                      , cl_nv_d3d10_sharing
                      , cl_nv_d3d11_sharing
                      , cl_nv_copy_opts
                      , cl_khr_gl_event
                      , cl_nv_create_buffer
                      , cl_kernel_attribute_nv
      [2      ][dbgerr][19828] AssertFailedException: "NVAPI_OK == p_status" - void __cdecl `anonymous-namespace'::CheckStatus::Check(const enum _NvAPI_Status,int)
      At:
              [0]00007FF62DD2F1FE              (0)
              [1]00007FF62DD30301              (0)
              [2]00007FF62DD29062              (0)
              [3]00007FF62DD2CCF8              (0)
              [4]00007FF62DD25E1F              (0)
              [5]00007FF62DD1183C              (0)
              [6]00007FF62DD13728              (0)
              [7]00007FF62DD430F0              (0)
              [8]00007FFA99FB7614     BaseThreadInitThunk      (0)
              [9]00007FFA9ADC26A1     RtlUserThreadStart       (0)
      Failed to add/update profile.
      NVidia driver installation found.
      Driver: 45266
      Branch: r450_00
      Found an existing profile: Ansys Workbench Products
      settings:
      Enable application for Optimus(0x10f9dc81) = 1
      Shim Rendering Mode Options per application for Optimus(0x10f9dc84) = 0
      Optimus flags for enabled applications(0x10f9dc80) = 1
      applications:
      Found an existing profile: Ansys ACP
      settings:
      (0x20335bca) = 0
      Error occurred during profile update.
      exception: AssertFailedException: "NVAPI_OK == p_status" - void __cdecl `anonymous-namespace'::CheckStatus::Check(const enum _NvAPI_Status,int)
      ********************** ERRORS *********************
      [1      ][dbgerr][19828] NVAPI call failed with: NVAPI_INVALID_USER_PRIVILEGE @269
      [3      ][dbgerr][19828] NVAPI: Failed to check profile.
    • Devendra Badgujar
      Hello Dr. Lisa Lust
      If you are using Discovery on a Virtual machine, you will also need the local device to meet the minimum hardware requirements as well along with the Virtual Machine.
      Please check if you have the minimum requirements for both. Let me know if further assistance is needed.
      Regards.
  • The topic ‘Graphics Card Discovery EMA 3d Install’ is closed to new replies.
