The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Materials
Materials
Topics related to Granta Design and more.
Granta and ACP
    • joaopedro.cs08
      What is the difference between the pre-post ACP lamination and the Granta selector?
    • David Mercier
      Ansys Composite PrepPost (ACP) is an integrated tool in the Workbench platform dedicated to composite laminates modeling (Pre) and advanced analysis results (Post) using dedicated failure tools. ACP allows to generate FEM models with different lamination regions defined layer-by-layer, it uses the Ansys Mechanical solvers to perform implicit / explicit structural and thermal simulations, as well as fluid-structure interactions.
      ANSYS Granta Selector is a powerful material database and selection tool especially if you need to replace an existing material with a new material. A number of filters are available that allow design engineers to select materials on manufacturing process, weight, cost and engineering properties...Selector contains as well an eco-audit tool, a synthesizer (analytical tool to estimate properties of composite/architectured materials...), an exporters to send materials data into your simulations.
