January 22, 2021 at 11:03 pmAkash564SubscriberHow to increase the mesh size gradually in the flow direction?nThanksn
January 25, 2021 at 4:42 amKeyur KanadeAnsys EmployeePlease have a look at growth rate option in sizing. If you are doing fluids simulation, growth rate of 1.2 is sufficient. nPlease also have a look at BOI, face sizing etc. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
January 25, 2021 at 9:45 pmAkash564SubscriberHello Keyur! Thanks for the info. I'm using slices to create multiple bodies for meshing with different elements size in the flow direction and body sizing for these. I've been using the growth rate close to 1.2. But, I don't see any significant variation in those sliced bodies. All the elements in these sliced bodies are of the same size. nIs there anything better than the body sizing for defining the gradual growth of the cells in the flow direction?n
January 27, 2021 at 6:57 amKeyur KanadeAnsys EmployeePlease check global sizing. Make sure you have defined min and max values correctly. nAlso when you say slice, make sure it has sufficient space to increase element size. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
- The topic ‘Gradual Increase in the Mesh Size’ is closed to new replies.
Ansys Innovation Space
- CONVERTING STL FILE IN TO SOLID
- Varying ply angle in ACP
- The meshing algorithm cannot find matching topology
- Assiging one parameter as thinkness of few shell objects
- [ANSYS Meshing] how to activate curvature for a sizing in a script?
- How to create a mapped mesh in a chain link model with stud.
- ICEM O grid mesh for sloped pipe
635
599
591
366
