December 2, 2024 at 4:25 pm
partha.nakti
SubscriberHello,
I'm using the Lumopt Python API with Lumerical FDTD for inverse design simulations and encountered an error (see attached) when attempting to enable GPU (Nvidia Geforce Rtx 4090) acceleration. I had three unoccupied FDTD licenses at the time.
Is GPU acceleration supported for inverse design tasks using Lumopt? Could the error be related to licensing, or is GPU acceleration incompatible with inverse design?
Thank you.
December 4, 2024 at 12:54 am
Lito
Ansys Employee@partha.nakti,
Python API or Optimization (lumapi/lumopt) requires a GUI connection and will checkout a GUI license. See this KB for more info. GPU is only used when you run the simulation file (.fsp).Â
Are you able to open the Lumerical FDTD CAD/IDE?Â
/opt/lumerical/v232/bin/fdtd-solutions &ÂHow are you configuring your simulation and resources to use GPU when running the simulation? (see KB for details)Â
Which Linux distro and version are you on?Â
cat /etc/*releaseWhich specific release of Lumerical 2023 R2 are you running?Â
/opt/lumerical/v232/bin/fdtd-solutions -v
/opt/lumerical/v232/bin/fdtd-engine -vLooking forward to your reply.
August 18, 2025 at 6:52 am
younglive2005
SubscriberHave you resolved this issue?
5649
1885
1404
1303
