February 22, 2021 at 10:53 am
Eclair
SubscriberHi, I'm working on the Modal Analysis of Rotor Dynamics.nHowever, when I tried to solve that, I got unknown error message.nI read the solution information, and I found the error part.nn*** ERROR ***                          CP =      5.609  TIME= 19:39:36n Resources file 'C:\Program Files\ANSYS Inc\ANSYS                       n Student\v211\CommonFiles\Language\ko/fx0.msb' not found.               n CADOE_LIBDIR211 = C:\Program Files\ANSYS Inc\ANSYS                     n Student\v211\CommonFiles\Language\ko.nnI don't know what fx0.msb means, and also curious about why resources file of korean is needed,nas Ansys doesn't support the Korean language.nnHow could I solve this problem?nAny suggestion or help would be appreciated. Thanks.n -
February 22, 2021 at 4:52 pm
ANSYS_MMadore
Forum ModeratorArray Please check your environment variables as you may see CADOE_LIBDIR211 = C:Program FilesANSYS IncANSYSÂ Studentv211CommonFilesLanguageko. Can you try changing "ko" to "en-us"?
February 23, 2021 at 2:24 am
Eclair
SubscriberHi, mmadore.
Thanks for your suggestion.
I couldn't understand that how can I change my environment variables you suggested, but I think that I found the solution.
I just created a new directory what error message said, and copy-pasted fx0.msb file. And it worked well.
I really appreciated for your help. Have a nice day!
August 2, 2021 at 5:52 am
verma20620
Subscriber.hi, Eclair!
I'm also getting same problem. Can you please tell me from where did you find this file fx0.msb ?
February 2, 2023 at 2:40 pm
fares abbara
SubscriberHello, I ran into a similar issue. Did you ever figure out the problem ? -
March 15, 2023 at 1:39 am
Guo-Feng Huang
SubscriberI solved the problem by following that address to that language file, and go into en-us file copy the fx0.msb out to language file.
Viewing 5 reply threads
- The topic ‘Got some errors on running Ansys Mechanical’ is closed to new replies.
1890
1414
1304
