April 1, 2025 at 8:15 am
ngv-wg22
SubscriberThe things now I create a box and assign it as an Oil, and create two hemisphere electrode to act as the ASTM D1816 test method. In the Simulation, I set one side of the electrode is 60kv another side is 0kv because I want to see the breakdown voltage occurs or not but the things is I want to see the Electric field. I got do two version for seeing the Electric field can help me see it the way that I set for investigate the Electric filed correct or not? Or you got a way to see the Electric field faster
April 2, 2025 at 4:15 am
Takeshi Itadani
Ansys EmployeeDielectric breakdown cannot be checked with HFSS or Maxwell.
With Ansys Charge Plus, air dielectric breakdown and charging of dielectrics can be checked.
Ansys Innovation Space
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
960
841
599
591
