April 1, 2025 at 3:31 am
ngv-wg22
SubscriberThe things now I create a box and assign it as an Oil, and create two hemisphere electrode to act as the ASTM D1816 test method. In the Simulation, I set one side of the electrode is 60kv another side is 0kv because I want to see the breakdown voltage occurs or not but the things is I want to see the Electric field. I got do two version for seeing the Electric field can help me see it the way that I set for investigate the Electric filed correct or not? Or you got a way to see the Electric field faster
April 1, 2025 at 8:00 am
Erik Kostson
Ansys EmployeeHi
I would suggest to post this in the Electronics forum (this forum is for SC and Discovery mainly and 3D CAD design).
All the best
Erik
April 1, 2025 at 1:41 pm
MirandaH
Ansys Employeehi, did you plot the field on a sheet object? -
April 1, 2025 at 2:24 pm
ngv-wg22
Subscriber-
April 1, 2025 at 5:06 pm
MirandaH
Ansys EmployeeThis works! You can also select the XY/YZ/XZ plane and plot it on to see a larger area.
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
2773
965
841
599
591
