July 5, 2025 at 7:03 pm
devashish.wanjari
Subscriber**Core Specification:** Cell Size: 6.4 mm, Foil Thickness: 0.025 mm, Material: Aluminium, Cover Plate Material: Aluminium This is the experimental model I am using to simulate the modal analysis of the Honeycomb Sandwich Panel. Currently, I am facing an issue where, when using default meshing with fixed support boundary conditions applied to the holes, I obtain different mode shape data. Conversely, when I refine the mesh size, setting the core's element size to 1 mm and the cover plate's element size to 2 mm, I find that mode no. 6 exhibits only edge deformation. I suspect that the small foil thickness is introducing errors. After conducting some research to address this problem, I learned that converting the sandwich model into a surface model can be beneficial. I attempted this using two methods: 1. **Mid-Surface Method:** In SpaceClaim, I created a mid-surface and bound the two solid cover sheets (made of aluminium) using a manual contact region. I then applied the boundary conditions. However, this approach resulted in only the core edges showing mode shapes, while the cover plates remained stiff, leading to incorrect results. 2. **Honeycomb Creator Extension:** In my second attempt, I used the honeycomb creator extension to model the core and created two surfaces on top to represent the cover sheets. Unfortunately, this method also failed. I am seeking guidance on how to effectively simulate the modal analysis of a honeycomb sandwich panel using a surface model with better mesh quality. It is essential to maintain an accurate representation of the honeycomb core, as I plan to procemessed to optimisation following the modal analysis.
July 6, 2025 at 4:39 am
Dennis Chen
SubscriberHello, I assume you have experimental modal analysis results and does that indicate there's no edge-only mode shapes?
If you look at your modal analysis, and you look at the mode shapes with the highest participation factors/modal mass, do you get the mode shapes you expect with the expected natural frequency?
I believe these mode shapes where only an edge has deformation will exist in the modal anlaysis but you should see a very small participation factors.  Furthermore, a lot of these modes would be very closely related (very close in natural frequency).   In reality, I would question how these mode shapes would be manifested when you do excite the structure in those directions... with added effect of damping as any real life structures would have.Â
3797
1388
1188
1095
1015
