getting “unable to create child process” error and “attempted launch of solvers via MPI failed”error
May 13, 2022 at 10:36 pm
steve.martindell
SubscriberOK, this is on the WinPC version of Ansysedt-2022-R1, getting the above errors when running frequency sweeps on a 3D structure.
Question1, do I need to install "MPI" ?
Question2: how do I debug these two errors ? , which I think are related.
July 29, 2022 at 2:12 pmPraneeth
Ansys EmployeeHi Steve,
Are you simulating the simulation model in cluster? If yes, then you need to install MPI. MPI is not required if you are running on a normal computer.
It looks like the errors on the screenshot are related to MPI. Please check if it is setup correctly.
All the very best,
Praneeth.Viewing 1 reply thread- The topic ‘getting “unable to create child process” error and “attempted launch of solvers via MPI failed”error’ is closed to new replies.
5024
1708
1387
1248
