Getting path temperature through mAPDL
    • thermalsr71
      Hello, My mAPDL model contains several paths inside a name selection, along which I calculate the temperature and output it to a file. I would like to visualize the path, either in POST or PRE-treatment, only to see if I am correctly setting it.
      However, I do not know the commands to do that in APDL.
      Can someone help me please?
    • ErKo
      Hi
      Not sure exactly what you mean as you mention named selections which is workbench (WB) / mech. related - in mapdl it (named selection) is called components so cm command is used - the below might be of some help perhaps.
      The below video shows how to get results on a path in mapdl:
      https://www.youtube.com/watch?v=cjfiqwx-GgE
      And the apdl manual:
      7.2. Reviewing Results in POST1 (ansys.com)
      See here how to open and see the above help link:
      /forum/forums/topic/how-to-access-the-ansys-online-help/#:~:text=Here’s%20how%20you%20can%20access,A%20browser%20window%20will%20open.
      The below shows how to get results on a path in WB/Mechanical:
      https://www.youtube.com/watch?v=91q283xj3iM
      All the best
      Erik
    • thermalsr71
      Thank you Erik, but that does not really work for me since the paths that I create (through APDL commands in the ANSYS Mechanical environment) do not appear when I load either the db or the rth file in ANSYS APDL.
    • ErKo
      You can open up a support request and we will be happy to help you there.
      Closing here.
      All the best
      Erik
  • The topic ‘Getting path temperature through mAPDL’ is closed to new replies.
