October 2, 2024 at 6:58 pm
jacob.lurvey
SubscriberHi All,
I'm struggling with performing what I think should be a relatively simple task. I have an .STL geometry that I import into SpaceClaim as facets, and I want to keep it that way for eventual import into Fluent Mesher as an .scdoc. It is imported already clipped at both ends, so I know the location of the inlet and outlet. I've attached a picture of the geometry.
What I want to do is to get all the faces on the inlet and outlet (shown highlighted in orange here) and put them in a named selection. Ideally, I would select all faces with the correct normal vector, but any method that will allow me to automate named selections for the inlet and outlet will work.
 The reason I need to automate this is because I want to process a whole load of similar geometries, all of which have known normals for the inlet and outlet facets. However, since I have to call GetRootPart.Meshes[0] instead of GetRootPart.Bodies[0], lots of the methods in the documentation don't seem to work. Is there any way to do this in SpaceClaim scripting?
Thanks for any help you can provide
October 14, 2024 at 6:45 am
Atharv Joshi
Forum ModeratorHi Jacob,ÂÂThanks for sharing the details about your problem.ÂLet me check this and get back to you.ÂÂRegardsAtharv -
October 16, 2024 at 3:19 pm
jacob.lurvey
SubscriberI managed to solve the problem using the following code:
inlet_selection = Selection.Create(
  RayFire.Fire(
    inlet_rayfire_origin,
    inlet_rayfire_direction,
    pixel_size,
    hit_radius
  )[1].GetConnection(0))inlet = NamedSelection.Create(inlet_selection, empty_selection, "mass-flow-inlet")
where inlet_rayfire_origin and inlet_rayfire_direction are a Point and Direction, respectively. Not sure why I have to call RayFire.Fire()[1] instead of [0], but it throws an error otherwise. Any ideas on why? It would be interesting to know. The call to .GetConnection(0) allows me to select all the coplanar facets.
5939
1307
