TAGGED: apdl, parametric, parametric-analysis, parametric-optimization, pyansys, thread
March 22, 2023 at 1:05 pm
Jake
SubscriberHello,Â
I have a parametric thread model, and I'm trying to get the parametrized pitch dimension from the model geometry on each run and pass it to APDL. Is there anyway to achive this?Â
Thanks.Â
March 27, 2023 at 3:56 pm
wrbulat
Ansys EmployeeHi Jake,
Was your parameterized geometry created in a CAD application outside of MAPDL? What do you intend to do with the thread pitch dimension once you have it in MAPDL? Do you want MAPDL to change the geometry if you change the value of the thread pitch in MAPDL, or do you instead intend to use the pitch doimension in some other way - say, in some kind of expression for post processing purposes?
--Bill
March 28, 2023 at 1:58 pm
Chandra Sekaran
Ansys EmployeeYou can take an already defined parameter in Workbench and assign it to a APDL parameter in the 'commands' object as shown below. Here I marked a pressure load in WB/Mechanical as a parameter (P1). Then I created a command object and made ARG1 a parameter (P2 in picture). Then you can set P2's expression as "P1/1 [Pa]" as shown in red circle in picture below. This is required to make it dimensionless MAPDL quantity. This will make arg1 equal the pressure value. Then in the commands you can use arg1.
Chandra Sekaran
Ansys EmployeeYou should be able to use this method for geometric parameters or any parameter that shows up in parameter set.
March 28, 2023 at 6:54 pm
Jake
SubscriberHi Bill,
The geometry is created in Autodesk Inventor, I am loading the geometry into workbench and simplifying/modifying with Spaceclaim then setting up my analysis in mechanical. I am using Spaceclaim to take the 3D Inventor geometry and turn it into a 2D axisymmetric cross section and to access the geometrical parameters from Inventor.
I intend to use the pitch to calculate thread dimensions so I can dynamically create named selections for each thread contact and retrieve the reaction force data for each thread contact as the pitch/geometry changes. The pitch will be changed via a parameter in a DesignXplorer and passed back to inventor for the model to be updated automatically. Â
I was originally trying to accomplish this via ADPL but it appears as if ADPL cannot access contacts. I believe I will need to use the python scripting feature in mechanical.
Thanks.Â
March 30, 2023 at 8:13 pm
wrbulat
Thanks for the additional details.
This (APDL code below) may (or may not) be helpful. If the number of threads is paramemetrized ("n_threads") and your 2D axisymmetric model contact is asymmetric, then this code might work on your model. It's objective is to create a unique named component for each group of the nodes used by the contact elements on each thread face. This assumes there are gaps in the contact elements as you go up the threaded fastener (e.g., there aren't any contact elements on the non-contacting face of each thread). If, in your project, you save nodal force results (under Analysis Settings Details), then you should be able to select each nodal component and use FSUM, then *GET,name,FSUM,,ITEM,FY to get net thread contact force for each thread individually.
n_threads=5
C*** ASSIGN UNIQUE COMPONENT NAMES TO NODES USED BY CONTACT ELEMENTS ON EACH THREAD FACEesel,s,ename,,172 ! SELECT CONTACT ELEMENTSnslecm,contact_e,elem ! NAME CONTACT ELEMENTScm,contact_n,node ! NAME NODES USED BY CONTACT ELEMENTScm,contact_n_i,node ! UNPROCESSED CONTACT NODES IN PASS i IN DO LOOPÂ*do,i,1,n_threads ! LOOP OVER # OF THREADS cmse,s,contact_n_i ! SELECT UNPROCESSED CONTACT NODES *get,ymin,node,,mnloc,y ! ymin = MIN Y LOCATION OF SELECTED NODES nsel,r,loc,y,ymin ! RESELECT THE NODE AT y=ymin n_start_i=ndnext(0) ! n_start_i = THIS NODE'S NODE NUMBER d_eselnum=1 ! INITIALIZE CHANGE IN NUMBER OF SELECTED ELEMENTS *dowhile,d_eselnum ! DO WHILE CHANGE IN # OF SELECTED CONTACT ELEMENTS IS NONZERO esln ! SELECT ALL ELEMENTS USED BY SELECTED NODES cmsel,r,contact_e ! RESELECT CONTACT ELEMENTS *get,n_esel_1,elem,,count ! n_esel_1 = # OF SELECTED ELEMENTS nsle ! SELECT ALL NODES USED BY SELECTED ELEMENTS esln ! SELECT ALL ELEMENTS USED BY SELECTED NODES cmsel,r,contact_e ! RESELECT CONTACT ELEMENTS *get,n_esel_2,elem,,count ! n_esel_2 = # OF SELECTED ELEMENTS d_eselnum=n_esel_2-n_esel_1 ! d_eselnum = CHANGE IN # OF SELECTED ELEMENTS *enddo cm,contact_n_%i%,node ! NAME CONTACT NODES ON THREAD i nsel,inve ! REDEFINE contact_n_i TO NOT INCLUDE NODES ON THREAD i cmse,r,contact_n_i cm,contact_n_i,nodeÂ*enddo ! END DO LOOPÂÂÂÂesel,all           ! THE FOLLOWING POST PROCESSING (UNDER SOLUTION BRANCH) IS UNTESTEDesel,u,ename,,172Â*do,i,1,n_threads cmsel,s,contact_n_%i% fsum *get,net_FY,fsum,,item,fy my_net_FY_%i%=net_FY*enddoÂÂÂÂÂ
- The topic ‘Getting Geometric Parameters in APDL’ is closed to new replies.
4678
1565
1386
1241
