April 25, 2022 at 5:06 pm
sivamk
SubscriberI imported model from catia to workbench and while doing meshing it is showing nothing but while obtaining solutions it is showing an error like invalid body with zero volume ,can any one please help in figure it out
April 26, 2022 at 2:16 pmVigneswaran Sridharan
Ansys EmployeeHey If you set the thickness of your imported surface to any value you should get past the error message (invalid volume error) and your model will solve. If you change that thickness to any other non-zero value it will solve again AND the results will be the same as the first non-zero thickness analysis. So if you put in a non-zero value you can get Mechanical to solve and the thickness is irrelevant but necessary (as far as analysis without acceleration is concerned).
If you click on the model at the geometry stage does the volume return a value (ie m^3)?
Are you able to right-click on the message and go to problematic geometry? If not how many bodies are there in the tree? If there are few can you check the volume properties of each body: And see if it shows some finite and valid number? Once you isolate that body you can check the source for the body and repair or suppress it in CAD.
Vigneswaran
Ansys Help
Rules & Guidelines ÔÇö Ansys Learning Forum
August 30, 2023 at 8:56 amPoudan Kumar
SubscriberInvalid body with zero volume pops when i try to solve.I am beginner and stuck with this problem.Could some one help?
I amÂ
Viewing 2 reply threads- The topic ‘getting an error like invid body with zero volume while doing analysis in static strutural’ is closed to new replies.
4783
1566
1386
1242
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
