Ansys Free Student Software
Getting a script error code: 80004005 Line:45377
    • moawezawan
      Hi! I am not sure why but I am getting this error consistently every time I try to open Ansys mechanical. I have tried uninstalling and reinstalling but I am still getting this error. Please help! thanks!
      Can you look in Workbench to see if there are any messages there too?
    • moawezawan
      That's the error message showing. It is weird because it was working fine a few days ago.
    • moawezawan
      sorry accidentally clicked on the solution option...and it isnt geometry issue its something with the mechanical interface of workbench.
      Edit: rwoolhou. No worries. Think deleting my post fixed it: will wait for Win to get on.
    • tsiriaks
      moawezawan,
      Try this.
      Make sure all ANSYS applications are closed, then try registering the DLL's by starting a Command Prompt with "run as administrator" ,  and issuing the following commands
      regsvr32.exe ole32.dll
      regsvr32.exe atl.dll
      regsvr32.exe oleaut32.dll
      regsvr32.exe scrrun.dll
      regsvr32.exe jscript.dll
      regsvr32.exe vbscript.dll
      All must say successful.
      Then, open up a regular Command Prompt , do not "run as administrator", and issue the following command
      move "%appdata%ansys" "%appdata%ansys.old"
      Thanks,
      Win
    • Vlad5435
      I had the same issue and this solved it. Thank you Win
    • Tejas1012
      I'm getting same error please help
    • felippeyo
      Hi, I could fix the problems using the same steps
      For the first part you can watch this video:
      https://www.youtube.com/watch?v=8ZG8WiW8x8I
      Inside the prompt you will insert the commands:
      And after this step you should go to Disk C:-> Users-> The folder with your name -> AppData -> Roaming -> Ansys. So you can rename the folder with your license (mine for example is v201) for "(Your License)_old" (mine for example v201_old).
      I hope it works
    • user deleted
      Hello Win, can you please help me?
      I seem to get the same issue.
      I have tried to run the scripts in the command prompt, but several of them didn't run, see below.
      In addition, I cant find this appdata. This is my working laptop, I am afraid to do something wrong, but maybe it is better to reinstall ansys at all?
      Thank you for help.
      Please, let me know what I should do to fix this.
    • feliperignacio
      hey guys,
      all the codes that i executed say succesfull but in my desk i dont find the folder ¨app data¨ instead i got ¨calibry library¨ with the file named ¨metadata¨ what to do in this case???
      pls help me - sorry for my english
      felipe
      appdata is the location for all of the user settings (graphics etc) and can cause problems with the software if it corrupts.   If you've run a model the files should be wherever you saved Workbench.
    • HeMeng
    • banubanu
      Thank you so much, I have been facing error "Line 45950 80004005" for three hours and your directions worked. Now my Ansys is back to its healty life :) I will pray for you all to be saved by others in your hardest times.
      Greetings from Turkey
      Banu
    • manu_98
      Hey guys, maybe one of you can help me.
      I have the same problem as the guys before me but im not able to solve it.
      Where do i have to insert the
      part? And do I have to add it with the "% or without? I really need held (sorry for my English)
      Greetings
      The %appdata% is a Windows file that stores preferences, typically in
      C:UsersusernameAppDataLocalAnsys
      C:UsersusernameAppDataRoamingAnsys
      You need to rename the folder that links to the version of Ansys software that you're having problems with.
    • manu_98
      Hey Rob,
      I found the folder and changed the name to .old gut its not working anyway....
    • harishravikale.201ch024
      felippeyo,thank you so much. I was trying to resolve this error for a long time.
    • MihaiCadis
      How can we solve this problem in linux?
    • mcmp
      I was getting the same error code: 80004005, line: 92952, char:4. I was able to solve it using tsiriaks' advice.
      Thank you!
    • Nomiko
      I had this problem. ''Tsiriak"s advice helped me. Thanks
Viewing 19 reply threads
  • The topic ‘Getting a script error code: 80004005 Line:45377’ is closed to new replies.
