August 4, 2023 at 12:34 pm
Kauê Castro
SubscriberHello, Im having a rather simple problem: The velocity I get when simulating is different of what I specificated in the boundary conditions panel, Im using a velocity profile that I had previously simulated, that has a max speed of 10.5 m/s approximately.. when simulating, the jet only envolves 1.05 m/s max velocity. Im using only one cell condition that depicts the fluid domain.Â
August 4, 2023 at 12:41 pm
Forum ModeratorDo the coordinates of the profile file match the boundary it's attached to in the new model?Â
August 4, 2023 at 12:45 pm
Kauê Castro
SubscriberI've made sure it matches yes, including the mesh.
August 4, 2023 at 12:56 pm
Forum ModeratorIt should be OK then. Can you post velocity contour plots of the two surfaces with node values off?Â
- The topic ‘Getting a different inlet velocity value’ is closed to new replies.
