Get the average stress of a section using the “section plane” tool
    • leonardopicinin12
      Hi everyone, I would like to know if it is possible to define a cut surface with the "section plane" tool as the "geometry" that I want to see the results of. In the following example, I would like to know the average strain on the highlighted surface. This body was cut with the "section plane" tool. I also selected another face, to demonstrate which "tool" I would like to apply to the face highlighted with the arrow. Thank you in advance for your help.
    • Ashish Khemka
      Please see if the following post helps:
      Regards Ashish Khemka
      • Boonyanuch Suksawang
        I have similar issue but the link you provided seems to be broken. Could you repost the link?
        Thank you in advance.
    • leonardopicinin12
      Thanks, that's exactly what I was needing
  • The topic ‘Get the average stress of a section using the “section plane” tool’ is closed to new replies.
