May 10, 2019 at 2:32 pm
Gaddsch
Subscriber -
May 10, 2019 at 3:29 pm
May 10, 2019 at 3:33 pm
Gaddsch
SubscriberThis does not seem to apply for "imported pressure" Label. As mentioned, i tried that allready...
May 10, 2019 at 5:37 pm
jj77
SubscriberI appreciate that this did not work but there is no need to use that tone and use a dislike, have in mind that we are helping here without compensation on our free time from work. So we are just trying to help you guys (students) out, and many times we can, but not always unfortunately -
May 10, 2019 at 6:25 pm
May 10, 2019 at 6:48 pm
jj77
SubscriberNo worries this can happen when writing. If you attach THE. wbpz file we can have a further look -
May 12, 2019 at 1:22 pm
Gaddsch
SubscriberHello jj77, thank you for specializing. i just had to read a little bit about the file and how to attach. I hope this is what you asked for! i am having the issues at each imported pressure in transient or static structural that are opened in workbench
Edit. I am giving an error message on the board, but i dont have the wbpz available as save option. Also im not exceeding 230 MB any idea?
May 13, 2019 at 8:21 am
May 13, 2019 at 1:15 pm
Gaddsch
SubscriberThis worked. It will also kill the posibility to see Min and Max, but i just need an Image of the blade with imported load points so that totally works. Thank you for your help jj77!!!
May 13, 2019 at 1:31 pm
Viewing 9 reply threads
- The topic ‘Get rid of Label “Imported Pressure” in Mechanical’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
1495
1386
1209
