February 18, 2023 at 7:34 pm
Daniel Neubauer
SubscriberHello everyone,
I'm running APDL in batch mode, called from MATLAB. The calculation I do has a high number of load steps ranging up to 6000. As each step does take around 20 sec, I'd like to get some information on solving progress by getting the latest solved load step (or similar) as an indicator of progress.
Matlab waits for the system exec to be done, so I cannot track progress by reading the output file by matlab - at least not on my level of Matlab knowledge! Also manually reding the out file does not work since my computer cannot open the file thorugh editor as it becomes too large. Is there any other way APDL can transfer a message while solving?
Highly appreciating any idea or suggestion in which direction to search.
best regards
Daniel
February 20, 2023 at 8:31 am
erik.kostson
Ansys EmployeeHi
You should be able to see the solution progress in the solve.out file.
Hope this helpsÂ
Erik
February 20, 2023 at 4:46 pm
wrbulat
- The topic ‘Get Load Step Progress while doing APDL Batch run’ is closed to new replies.
