November 16, 2023 at 5:38 am
nurrizqi.2020
SubscriberWhat is the equation for finding the drag force using a wind tunnel without knowing the drag coefficient? Then, if use the momentum loss method, what is the formula for the equation?
November 26, 2023 at 3:34 am
Raihan Lutfianto
SubscriberPlease check this interesting forum Is it possible to find the drag force of an object without a drag coefficient? If yes, how? - Quora
- The topic ‘Get drag force from wind tunnel’ is closed to new replies.
