Ansys Products
Ansys Products
Geometry interface not found
    • GiulioValerio
      Hi, i have problems to open a dbs file with ansys 2021 R1, a message Geometry interface not found appears. It is a problem of license or i am opening the file in the wrong way?n
    • ANSYS_MMadore
      Array Are you running Ansys Student? If so, you would only have access to STEP and IGES files, and Parasolid natively within DesignModeler.nIf you look in your %TEMP%\.ansys directory there will be log files that will give more information if this is in fact due to a lack of license.n
    • GiulioValerio
      Hi, nThank you for your answer.nYes i am running Ansys Student, im sorry but i have no idea where to look for %TEMP%\.ansys, i found the lincenses.chromium, i dont know if its the same thing.n
    • ANSYS_MMadore
      Open a file explorer window and enter %TEMP%\.ansys in the address bar.n
    • GiulioValerio
      I have a list of AddinTemplates, can i upload a screenshot of that?n
    • GiulioValerio
      n
    • ANSYS_MMadore
      That's not right. nn
    • GiulioValerio
      Sorry for my ignorancenn
    • ANSYS_MMadore
      Please share the full contents of the licdebug.DESIGNMODELER.211.out and licdebug.FEAT_ADVANCED_MESHING.211.outn
    • GiulioValerio
      n
    • ANSYS_MMadore
      The .dbs file you're trying to import, into which application are you trying to import it? n
    • GiulioValerio
      I have to see the geometry, i am running Fluid Flow (Fluent), then geometry and Spaceclaim because i saw that it supports dbs files.n
    • ANSYS_MMadore
      It appears the Gambit Reader was discontinued as of Release 2020R1.n
    • GiulioValerio
      The Professor sent me this file. I have to tell him to convert it in another formatnThank younHave a nice dayn
      Assuming he has an older version of Workbench it'll read into DesignModeler and he can then export the agdb file (DM format) for you to use. I'd suggest he exports Step as that's also recognised by CAD and he can check it's valid. Note, the old Gambit reader won't pick up mesh or virtual geometry settings. n
Viewing 14 reply threads
  • The topic ‘Geometry interface not found’ is closed to new replies.
