June 16, 2023 at 8:14 am
June 16, 2023 at 1:28 pm
Sampat Kumar
Ansys EmployeeHi Ayeon Hwang,Â
Will you please explain the question in a little bit of detail? As I can see, the inner geometry is separated from the outer geometry in the first images. Are you expecting any radial contraction of the inner part of the geometry? Are you expecting the inner geometry to move opposite the movement in the attached image? It all depends on the boundary condition that you have applied.
Regards,Â
Sampat -
June 16, 2023 at 2:20 pm
Sampat Kumar
Ansys EmployeeHi,Â
It all depends on the geometry and boundary condition that you have applied. Will you please upload a screenshot of the original geometry and boundary conditions that you have applied?Â
Regards,Â
Sampat-
June 19, 2023 at 2:19 pm
Ayeon Hwang
SubscriberI made two solids in spaceclaim.
And I used the static structural function in workbench.
I don't know how to set a boundary condition here.
I've tried it on Fluent.
The two geometry have different properties.
I want the inner geometry to expand.The initial geometry is shown in the picture below.
How can you solve it?Â
And when I changed a function, the bent shape did not come out, and it only looks like the shape below.
Please help me
Thank you.Â
June 20, 2023 at 1:37 am
June 21, 2023 at 10:40 am
Sampat Kumar
Ansys EmployeeHi Ayeon ,Â
Will you please check the connection that you have applied for? Please establish contact between the two parts. Are you seeing the result on a large scale? I would recommend you see the result on a true scale.
You can adjust the pinball radius to detect the contact between the inner and outer geometry. You will find the pinball radius option in the contact details. You can also check the status of the contact by using the contact tool.
Regards,Â
SampatÂ
June 22, 2023 at 9:00 am
Ayeon Hwang
SubscriberHello.
Thank you for your answer.
I have already met the conditions.
But nothing has changed.
I changed it to Frictional, Frictionless, and no separate, but the result is the same.
Is there any other solution?Â
The inner geometry was defined as stent and the outer geometry as artery.
I want to see the effect of stent on the artery.
But my simulation result is that stent goes out of the artery.
The elasticity of stent was expected to inflate the artery.
How can I solve this?Â
Thank you.Â
June 22, 2023 at 1:23 pm
Sampat Kumar
Ansys EmployeeHi Ayeon,
I have performed a similar operation on a dummy model. I am able to see the impact of the expansion of inner geometry to the outer geometry.
I would suggest verifying the following points
1. Contact status- If the pinball radius is more than the geometric gap or not, if not then increase the pinball radius. right click in the connection –>Contact tool–> generate the contact information.Â
2. If the applied pressure is enough to expand the inner geometry for making contact with the outer geometry in the true scale.Â
3. Plot the separate deformation for the outer geometry and inner geometry to see the deformation in both parts.Â
4. keep large deformation ON in the analysis setting.Â
Regards,Â
SampatÂ
June 28, 2023 at 1:33 am
Ayeon Hwang
SubscriberI'm using the 2020 R1 version.
But the 2020 R3 version is also available.
Can I know what's wrong with my work?Â
Thank you
June 28, 2023 at 11:00 am
Sampat Kumar
Will you please tell me the issues in detail? Where is it available? Or you can post this in the separate forum question so that this forum thread would remain separate for your model-specific and problem-related contact and boundary condition.Â
Regards,Â
SampatÂ
June 26, 2023 at 5:45 am
Ayeon Hwang
SubscriberI did what you said, but I think I'm doing something wrong
Can you check my workbench file? I give you a link.
   >> https://drive.google.com/file/d/1w-2-RpQeCO8ftRC7pvpprdcRqe35a87S/view?usp=sharing
Is there a problem with this warning?
And when 'contacts' was 'no separate', this shape came out.
Is it because the geometry is not flat?
thank you.Â
June 28, 2023 at 10:55 am
Sampat Kumar
Ansys EmployeeHi Ayeon,Â
We Ansys employees are not allowed to handle any external links or files; maybe someone outside of Ansys would help you with this file.
Your model has converged with your loading and boundary conditions. The solver has automatically added a Weak spring to converge this model.
What type of result do you obtain when you use frictional contact instead of no separation contact?
SampatÂ
- The topic ‘Geometry in Static Structural Mechanics’ is closed to new replies.
5824
