September 11, 2019 at 7:36 pm
Harrison117
SubscriberHi im working on a drop vehicle project for my university and I'm attempting to run a CFD analysis and FEA on my vehicle. However whenever I create an enclosure it increases my face count over the limitations. Then when I use a Boolean tool to subtract the vehicle from my enclosure it reduces down the face limitation under 300. When I try to run the mesh section ansys gives me these errors
How do i get around this? BTW im used solidworks for my part assembly it initially has 173 faces.
September 12, 2019 at 1:43 am
peteroznewman
SubscriberWhen I am in SpaceClaim, it doesn't complain about the number of faces until I try to save so I don't understand what your problem is.
September 12, 2019 at 1:52 am
Harrison117
Subscriberim using design modeler but basically the geometry saves okay but the moment i try to move on to the mesh portion it gives me those errors above. Im trying to run a airflow sim on fluent.Â
Im not sure if its because i originally went over the student ansys limit of 300 faces with my added enclosure tool or if there's something wrong with the initial cad
September 12, 2019 at 2:17 am
peteroznewman
SubscriberFile > Archive and create a .wbpz file then attach that file after you reply with the Release of ANSYS you are using and I will take a look.
September 12, 2019 at 2:30 am
Harrison117
Subscriber Im using Ansys workbench 2019 R1
September 15, 2019 at 12:10 am
peteroznewman
SubscriberHello Harrison,
I opened your model, in 2019 R1, I opened SpaceClaim and I used the Repair tab to remove Extra Edges. Then I did the Enclosure. Then I deleted the solid body so I only had the enclosure solid, because keeping both would exceed the face count.
Here is a mesh with some inflation layers added.
- The topic ‘Geometry failed to interface’ is closed to new replies.
5649
1885
1404
1303
