Geometry Correction for Bolt Thread
    • Leydy Garcia
      I have a bolt and a nut with frictional contact. For geomectry correction , bolt thread,  the orientation which is set to "Program Controlled" remains yellow out. I can not find a way to fix this.  I have introduced all parameters such as mean pitch diameter, pitch distance, thread angle.
    • Aurojyoti Prusty
      Make sure that your scoping for contact is aligned with the specification provided in the below link.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_Contact_Scope.html?q=contact%20scoping
      Scope Settings (ansys.com)
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_contact_object_properties.html
      Contact Settings (ansys.com)
      You can try to flip the target/contact side by fliiping option available as per below link.
      Flipping Contact and Target Scope Settings (ansys.com)
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_Flip_Contact_Target_Scope_settings.html?q=contact%20scoping.
      I hope these option would help.
      Thank you.
      Aurojyoti.
    • Leydy Garcia
      Hi Aurojyoti,
      Thanks for the feedback. I checked specifications for scoping contact and they have no problem. Also tried flipping the contact and stills the issue is there. Is there any other option to fix the problem?
    • saffat.hossain
      Hi, this happens when you have selected multiple faces which are away from the target face and vice versa. I can see you selected 2 faces for target and contact. Can you post an image of your contact region? It would be 1 face for the hole and 1 face for the bolt ideally.
    • Leydy Garcia
      Hi Saffat,
      I made a section plane for better visualization. Here it is:
    • saffat.hossain
      Hi Leydy
      Thanks for the image. Do you have a split on the bolt? If not, create a split in the SpaceClaim geometry to match the nut face so that the bolt contact face has the same length as the nut length. You can easily create a split from the Design tab of SpaceClaim using the nut face to create a split on the bolt shank. This should resolve your issue.
      By the way, can you show which 2 contact and geometry surfaces that you have selected. I can only see one face for each in the image.
    • Leydy Garcia
      Hi Saffat,
      I can not find SpaceClaim. Do you have a tutorial of how to do the split?
    • saffat.hossain
      Hi Leydy
      There are many tutorials on YouTube for splitting a surface.
      You can open SpaceClaim by right clicking on your geometry (from project tree) and the selecting "edit with SpaceClaim".
      If you need support on how to do the split on your model, share your model by uploading a step file and pasting the link here.
Viewing 7 reply threads
  • The topic ‘Geometry Correction for Bolt Thread’ is closed to new replies.
