Generating Pressure Wave
    • Samar
      Hello everyone,
      Please (Using ANSYS WB) i want to generate a pressure wave that's resulted from a change in displacement (Deformation) according to the equation:
      where Vs is the Speed of sound for used material.
      So, how to get this propagating pressure? Which Module should i use?
      Any help is highly appreciated.
    • jj77
      This is an acoustic pressure wave equation for acoustic longitudinal waves in gases and fluids so you could use the acoustic capabilities in ansys.
      If you are interested in wave propagation in solids then we have shear waves also and so one could use explicit dynamics in ansys.
      See the help manual on acoustics and explicit dynamics
      I have seen that you have been posting about this for some time. If you give much more info on what you are trying to analyse then I might be able to give you some advice
    • Samar
      Ok, yes i had previously posted about this before & didn't get help. As well i tried to work with the Acoustic Modules in ANSYS Workbench but i wasn't able to get my required wave.
      Clearly what i am doing is using the (Transient Thermal) Module to get the Temp. map then use this temp. in the (Transient Structure) Module to get displacement "Deformation" resulted from the change in temp. in the objects, finally i use this "Deformation" results to get the pressure wave propagates in objects and no problem with me to change the used materials to be fluid in order to be able to generate the pressure wave.
      Are those information helpful or still need more clarification?
    • jj77
      OK, quite confusing. I assume you generate the pressure wave with the heating of the material, then there is no need to apply a second source of wave generation (say a force or pressure).
      As I said it is important to know the material you have because as I said solid material support two different waves (pressure and shear).
      Second of all what is exciting the wave - is the temperature or another form (say a force). With the temp. it should be possible like you have for instance laser excited ultrasonic waves in solids (due to rapid heating at the laser spot, the heat generated results in a wave in a metal say). So make sure the temp. increase is a transient, resulting in a transient force on the material and that might generate the wave.
      Finally to capture the wave it depends how long (in time/sec.) the pulse wave is - say it lasts ~ 1 microsecond, then dt (time step) in the transient analysis needs to be one tenth of that so 0.1 microsec or less (this is just an example you know the time duration of your pulse, so use that). That will make sure that at least ten sampling points are used to capture the pulse.In the paper you mention, they have duration of ns, so you need to have something like 0.1 ns then - in your simulation the heating lasts for a second! Make sure you understand how they heat up the tumour and the timescales which are really small -Peter pointed this out to you.
      So dt in thermal is one thing, but in transient structural we need to have enough time sample points to capture the pulse.
      That is for the time steps. Spatially now:
      Also we need to have enough elements to capture the physical extent of the pulse, so with the spatial dimension of the pulse (call it wave length), we need to have wave_length/8, element size.
      See this paper for some details.
      https://www.sciencedirect.com/science/article/pii/S0030399204002336
      https://www.researchgate.net/publication/286309111_Finite_Element_Simulation_of_Laser_Generated_Ultrasound_Waves_in_Aluminum_Plates
      https://ndtlibrary.asnt.org/2017/ThermoelasticFiniteElementModelingofLaserGeneratedUltrasoundinAdditiveManufacturingMaterials
      http://www.scielo.br/scielo.php?script=sci_arttext&pid=S1679-78252014001000004
      All the best of luck - that is it from me
  • The topic ‘Generating Pressure Wave’ is closed to new replies.
