February 10, 2021 at 5:52 pm
cascott5
SubscriberFebruary 11, 2021 at 10:10 am1shan
Ansys EmployeenPlease check this post /forum/discussion/18773/what-are-some-suggestions-to-increase-the-analysis-speed. Also, if you are open to hardware upgradation and want some info. do check /forum/discussion/1515/please-recommend-the-configuration-of-the-computer-workstation.nAt first glance it looks like a symmetric model, you could try modelling just the half part using symmetryc BC's. This would reduce the time considerably. Also, their are homogenized approaches to structures like foam and honeycomb where the cavities are modelled with additional inputs in material data, rather than meshing it to the finest details. You could have a look at research articles explaining these models.nnRegards,nIshan.nFebruary 26, 2021 at 3:33 amramgopisetti
SubscriberCan i know what solver are you employing to model the foam body, by that i mean, if you are familar with the LSDYNA -FOAM material MAT_005/MAT_SOIL_AND_FOAM, you dont need to model the microstructure of it, you can use the Experimental data which has followign information apart from isotropic eleasticity terms as follows n
2) if your aim was to describe the microstructure deforming mechanisms, your approachs is good, that said, if you want to refine the mesh, it will take some CPU time and its an tie off between fedility and time. nCheers,nRam n
Viewing 2 reply threads- The topic ‘Generating mesh for a foam’ is closed to new replies.
6745
1324
1047
