July 30, 2024 at 9:04 pm
vporwal
SubscriberÂ
How to resolve this error ? Â
*** Error 20065 (STR+65)
   reading joint card no. user ID 80001 (# 1 in the input order)
   Node 1 in rigid body A and node 2 in rigid B are NOT coincident.
   Their Coordinates should be adjusted.
 *** Error 20067 (STR+67)
   Node 3 in rigid body A and node 4 in rigid B are NOT coincident.
   Their Coordinates should be adjusted. Node ID= 855013
   reading joint card no. user ID 80003 (# 3 in the input order)
   Their Coordinates should be adjusted. -
July 31, 2024 at 3:29 pm
Alex Rycman
Ansys EmployeeHello,
*CONSTRAINED_JOIN_* requires that the nodal points within the nodal pairs used to define the joint (1, 2), (3, 4), and (5, 6) should coincide in the initial configuration. Please see Figures 10-16 through 10-22 in Keywords User manual I.Â
https://lsdyna.ansys.com/manuals/
E.g., revolute joint
Example: https://www.dynaexamples.com/introduction/examples-manual/constrained/joint-1
Example II: https://www.dynaexamples.com/introduction/examples-manual/constrained/joint-ii
Thanks,
Alex -
July 31, 2024 at 5:36 pm
vporwal
SubscriberThanks, that's resolved my problem.Â
- The topic ‘Error 20065 (STR+65) reading joint card no. user ID 80001’ is closed to new replies.
