January 16, 2024 at 8:54 am
January 16, 2024 at 7:01 pm
Amrita Pati
Ansys EmployeeHi Xie,
In Line 6, there is no semi-colon (;) at the end of the line.
Amrita-
January 22, 2024 at 12:03 am
January 22, 2024 at 6:14 pm
Amrita Pati
Before you run the script, make sure that all other files in the zipped folder (downloaded from the article) are in the same location.
Amrita -
January 23, 2024 at 2:32 am
January 24, 2024 at 9:59 pm
Amrita Pati
This is a bit strange. The same scripts are working for me. I have downloaded and tested since you started having the problem. From your screenshot I can tell that the required files:
Lumerical_GDS_autoexp_functions;
Lumerical_GDS_autoexp; are in the same directory.
Also, can you uncomment Line 74? We need Line 74 to be able to run the script successfully? Or is it also throwing the same error?
Amrita -
January 25, 2024 at 9:08 am
January 25, 2024 at 9:20 pm
Amrita Pati
Sorry this took me a while to figure out. Line 75 is incorrectly spelt. If you look at the folder, the name of the lsfx file is "Lumerical_GDS_autoexp".
So line 75 should be changed to:
Lumerical_GDS_autoexp;Â Â
Currently it is Lumerical_GDS_autoexport. And please keep Line 74 uncommented. Let me know what happens then.
Amrita -
January 26, 2024 at 2:06 am
zouxie
SubscriberHi Amrita,
Following your latest advice, all my problems have been solved, thanks for your patience in replying over such a long time. Good luck.
- The topic ‘GDS_auto_export_test’ is closed to new replies.
5884
1306
