July 23, 2021 at 10:07 am
Amith_Anoop_Kumar
SubscriberNot able to apply gasket behaviour for the body. hat is that I am doing wrong here
July 23, 2021 at 10:48 amErKo
Ansys EmployeeSearch this forum to see if you find something that helps:
Also the internet might have some tutorial on how to use this.
Goodluck
Erik
July 23, 2021 at 10:53 amAmith_Anoop_Kumar
SubscriberThe links int that isnt viewable as it was redirecting to the customer portal Sir. I had checked some tutorial in it they were directly selecting the behaviour as gasket and it was working but not in my case
July 23, 2021 at 11:09 amErKo
Ansys EmployeeIt is another post that might help - also search for similar posts in this forum, perhaps you will find something that helps.
Also show the material from engineering data, perhaps that is not defined as it should. Perhaps someone will be able to help then
Erik
Viewing 3 reply threads- The topic ‘Gasket material’ is closed to new replies.
5914
1306
