November 21, 2024 at 11:04 am
November 21, 2024 at 11:51 am
Harshvardhan
Ansys EmployeeÂ
In this model, why are you using bonded contacts? You should insert appropriate Joint Connections at all the joints in the model.For more information about joints, please go through the following links:
9.7. Joints
https://www.youtube.com/watch?v=il_OfGcXWYw&list=PLtt6-ZgUFmMKdzJIohbfiQyYSCAU42ZAOAlso, I can see that there is a penetration between two parts. This should be rectified in a 3D software.
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)Â
November 21, 2024 at 11:58 am
kubatycjan
SubscriberÂ
Thank you very much for Your response Harshvardhan, what kind of 3D software you propose to rectified those two parts ( sidebase 1 and 2) ?
Speaking of which why should I use joints ? Since I want my model to be immovable during analysis. I want to set my car jack on definied height and then see how force of 2T works on my toolÂ
November 21, 2024 at 12:57 pm
Harshvardhan
Ansys EmployeeÂ
Any 3D design software will do. Ansys also provides some CAD softwares, namely Design Modeler, Spaceclaim and Discovery.
Regarding the usage of joints, Bonded contact will can be equated to a welded joint. Since this is not the scenario in the real world, you should not use these. Using bonded contact will give incorrect results.
Harshvardhan
Ansys Help
- The topic ‘Gaps in self-made car jack’ is closed to new replies.
6795
1333
1152
