G RMS value of PSD
    • deepesh.p.gurdasani
      After we input PSD data, is there any way to directly see G RMS value of the same in ANSYS ? Just like we get the  G RMS value as one of the outputs in response PSD ?
    • Chandra Sekaran
      In postprocessor you can use the response PSD probe to get the acceleration response PSD at one of the nodes where the excitation is applied. The result will be in acceleration units (not in G). For example I applied a PSD as below:
      The response PSD at one of the nodes at the fixed support where I applied the PSD shows the correct RMS value.
      What I meant was, after we give input data, can we see RMS value of input PSD data ?
    • Chandra Sekaran
      No, that feature is not available in the preprocessor.
  • The topic ‘G RMS value of PSD’ is closed to new replies.
