Electronics
Electronics
FW and MTPA characteristic
    • Cesar0103
      Hello!!!!nI am working with a magnet assisted synchronous reluctance motor (PMa-SynRM) and I am trying to get the constant power characteristics. Without the assistance of the magnet I obtain the characteristic constant torque through the Machine Toolkit, but when I use the magnet the characteristic doesn't give me something reasonable. Does this kit not work for this type of machine?nCould you tell me if there is a tool to calculate the constant power characteristic or any suggestion to obtain it, any idea or suggestion is good....nnThanks!!!!!n
    • Navya C
      Hi @CesarnPMASRM is also a kind of IPM machine. Machine toolkit supports IPM machine.nSo it should work for PMASRM as well I think.nnnBest regards,nNavyan
    • Cesar0103
      Hi NavyanI tried to simulate it as an IPM but it gave me inconsistent results. I'll give it a try....nThanks for your time....nBest regards,nCesarn
    • Cesar0103
      nI followed his advice and ran the simulation as a IPM machine, but the results I don't think are correct, I show younnwithout PMnnwith PMnnTheoretically, the torque on the assisted machine must be higher, but it is not the case...the simulation was carried out under the same conditions.nBest regards,nCesarn
  • The topic ‘FW and MTPA characteristic’ is closed to new replies.
