結構
結構
Function Expression for Force based on Joint Speed in Ansys Motion,
    • B10838033
      I am using Ansys Workbench Motion and need to define a force that dynamically updates based on a joint's rotational speed during the solution (e.g., the force increases as the speed increases).
      Could you please advise on:
      What is the exact Function Expression syntax to extract a joint's rotational speed in a specific direction (e.g., Z-axis)?
      How can I integrate this speed variable into a Force expression correctly?
      Any simple syntax examples would be highly appreciated.
      Best regards,
    • dlooman
      Does the explanation below help?
      How do you specify a joint moment as a function of rotational velocity in the Motion product?
      In Ansys Motion you can apply a joint moment via a function expression, and this function can use a measure (such as the joint’s rotational velocity) as its input; you define the velocity measure for the joint, then assign it as the input of a torque (moment) function so that the applied torque becomes a user-defined function of that velocity.
      1. Applying a joint moment using a function expression
      • You can create a Joint Moment load and set its Moment to Function Expression, then select a torque expression (for example based on STEP or other functions) as the definition of the joint moment.
      • In the Details of “Joint Moment”, the torque can be defined directly as a function expression (e.g. a step torque using STEP(TIME,…)), and this mechanism is the same place where you would use a velocity-based expression once the velocity is available as an input measure.
      2. Getting joint rotational velocity as an input measure (command-based)
      • The developer API provides a way to obtain the joint velocity: a joint is first found using CS_Joint.Find(_jid), and then its velocity measure is obtained with joint.GetVelocity().
      • That velocity measure can then be assigned as the input measure of a load (actuator) using load.SetInputMeasure(vel); this is how you connect the joint’s rotational velocity to the function driving the torque.
  • 必須登入。
