September 3, 2024 at 12:44 pm
luna6362
SubscriberHi everyone.
I need to measure the average fluid velocity in a specific part of my model, but I'm not sure which function to use within the Function Calculator.
There are four options that I think might be suitable, but the velocity results from these four options vary significantly.
Which one should I use to obtain the correct result? My simulation involves incompressible flow.
1.areaAve 2.ave 3.massFlowAve 4.massFlowAveAbs
September 5, 2024 at 9:38 am
Essence
Ansys EmployeeHello,
Since the flow is incompressible, no energy equation solved (simple flow without reversed flow), you know that velocity = (mass flow rate)/(constant density*cross section area). You can determine mass flow rate, density and cross section area. You can then verify with which of the four fits to your application.
September 5, 2024 at 11:56 am
luna6362
SubscriberHello Essence,
Thank you for your response.
Actually, my model is quite complicated.So it is hard to determine the velocity using that simple formulation.
And I just want to know the velocity of the upper part of my model.
However, I might use a simple tube model to confirm which function is suitable to use.
I will try it! Thank you so much!
September 5, 2024 at 1:43 pm
Essence
Ansys EmployeeYes, please use a sample case for the verification and get back in case you need help.
6535
1311
