Full Multicomponent Diffusion Option Under Species Transport Model Not Working
    • gmk29
      I am simulating two gases mixing in a T-junction, which are found in the Ansys data base. Initially, I selected species transport as the model and was able to select Full Multicomponent Diffusion with the default mixture material. When I defined my new mixture with the two gases, I also selected multicomponent for mass diffusivity and put it at a constant value. When I went back to species transport and selected this new mixture, it grayed out the Full Multicomponent Diffusion option and I am unable to select it when I have this new mixture chosen. I am new to Ansys so would appreciate some guidance as to what may be causing this. For reference, here are my steps:
      1) General Settings: Solver
      1) Type: Pressure-based
      2) Velocity Formulation: Absolute
      3) Time: Steady
      2)General Settings: Gravity
      1) X: 0 m/s2
      2) Y: -9.81 m/s2
      3) Z: 0 m/s2
      3) Models
      1) Species: Species Transport
      2) Reactions: none
      3) Options: Diffusion Energy Source + Full Multicomponent Diffusion
      4) Materials
      1) Fluid: gas1 and gas2
      2) Mixture: gas1_gas2_mix
      1) Names: gas1 and gas2
      2) Density: ideal-gas
      3) Cp: mixing-law
      4) Thermal Conductivity: mass-weighted-mixing-law
      5) Viscosity: mass-weighted-mixing-law
      6) Mass Diffusivity: multicomponent = constant
      5) Species Transport
      1) Mixture Material: gas1_gas2_mix
      If your mixture is only two species why would you need multicomponent?
