March 23, 2024 at 9:16 am
Swad Al Nahiyan
SubscriberI am attempting to simulate a unit cell utilizing a Floquet port. The unit cell contains a pin diode that operates in two states. This diode is connected to the ground via a metal via hole and also includes a bias line. What is the correct procedure to simulate this configuration?
Initially, I attempted to design the pin diode based on its equivalent circuit using lumped elements, specifically a rectangular surface with boundaries assigned as lumped elements. However, the simulation did not show any noticeable change in the S-parameters when compared to the unit cell without the diode.
Considering the entire setup from a circuit perspective, the bias line is connected to a controller. One end of the diode is connected to the ground, completing the circuit. For the simulation, I intend to use the equivalent circuit for a single stage (on/off) and thus, I believe the bias line may not be necessary. In this scenario, would the circuit be complete?
I have come across some demonstrations of pin diode design within a transmission line, where both ends of the transmission line have lumped port excitations. I'm also curious to know if any modifications are required when using a Floquet port for this purpose.
April 11, 2024 at 8:51 pm
Irina G.
Ansys EmployeeLumped RLC boundaries should work in Unit cell. How much difference in S-parameters (Mag and Phase) do you expect?
I would check first for Shorted / Open case as a base line.
- The topic ‘FSS unit-cell with pin diode simulation using Floquet port’ is closed to new replies.
5849
