April 15, 2019 at 1:01 pm
MostafaOdabaee
SubscriberHi there,
I’m trying to run a FSI steady-state harmonic acoustic simulation to estimate the attenuation of human skull exposed to ultrasound waves. I have basically the activated surface of the transducer (surface velocity), two acoustic regions (water, as the coupling medium between the surface of transducer and skull and also inside skull), one physics region (human skull), and FSI. The properties of human skull are shown in one of the attached pictures. However, this is not showing a noticeable amount of pressure drop (attenuation) once the ultrasound waves propagate through the skull. In another word, the transmitted pressure is not attenuated. I was wondering if someone could kindly help me to find the right solution for this? Thanks. Mostafa
April 16, 2019 at 8:41 pm
Hui Liu
Forum ModeratorHi Mostafa,
what is your mesh look like, and what's your frequency range for your solution? Is your element size small enough?Â
April 16, 2019 at 10:44 pm
April 19, 2019 at 5:32 pm
sk_cheah
SubscriberHi Mostafa,
From the images you posted, it looks like your analysis is 2D. That may be the problem. In 19.2 documentation on Harmonic Acoustic Analysis, it states:Â
This analysis supports 3D geometries only
Kind regards,
Jason -
April 29, 2019 at 1:00 am
- The topic ‘FSI steady-state acoustics’ is closed to new replies.
5654
1885
1404
1303
