FSI Simulation using Fluent Meshing
    • k1525166
      Hi All,
      Has anyone done an FSI simulation using FLUENT Watertight simulation before ?
      How did you connect the fluid to structural succesfully ?
      Any guidance or links for this would also be appreciated.
    • abhishek.roy
      Hi, are you referring to the watertight meshing workflow in Fluent meshing? If so, you will be able to generate the mesh using this; then, you need to switch to the Fluent solution. Refer to the tutorial below for FSI setup
      Chapter 28: Modeling One-Way Fluid-Structure Interaction (FSI) Within Fluent
