TAGGED: ansys-cfd, ansys-cfx, fluid-thermal-solid-interaction, fsi
September 28, 2023 at 9:18 am
dimitri.hamelin
SubscriberDear all,
I am actually facing a problem. I can not execute my Fluid/Solid Interaction.
Here is the warning I have before the error occurs: (I use a steady-state thermal analysis and a steady CFX problem, I say that because I saw for others the error occurs when the time staps were not the same)
| Warnings were found during data model validation. Â Â Â Â Â Â Â Â Â Â Â Â Â |
| Warning: Participant Steady-State Thermal (CouplingParticipant:Solution 12) |
|   has the ExecutionControl 'Option' set to 'ExternallyManaged'. System   |
|   Coupling will not control the startup/shutdown behavior of this     |
| Â Â participant. Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â |
| Warning: Participant Fluid Flow (CFX) (CouplingParticipant:Solution 13) has |
+-----------------------------------------------------------------------------+Â
Couls someone help me please ?
September 28, 2023 at 8:01 pm
Federico
Ansys EmployeeHello Dimitri,Â
these warning may not be related to the actual error. Can you share the error message instead?
- The topic ‘FSI Problems’ is closed to new replies.
5019
1708
1387
1248
