March 31, 2025 at 3:52 pm
230311002
SubscriberThe model is fsi I am simulating in transtional structure and system coupling is used to couple the fluid and wall. I need help on how to give 10 time step in analysis setup of wall for simulation and also want to know how to calculate the wall shear stress in fsi and how to calculate OSI
April 9, 2025 at 1:32 pm
Rahul
Ansys EmployeeI recommend going over this tutorial in the Ansys documentation to understand the two-way coupling setup Reed Valve FSI Co-Simulation with Partial Setup Export from Workbench (Fluent-Mechanical).Â
Ansys Innovation Space
- Calculation of Contact Normal and Traction Forces
- Car projection lamp Zemax design
- Torsional Stiffness calculation
- Interested in ROM building and deployment course
- Unable to login to Ansys Learning Hub
- FSI calculate OSI
- An internal solution magnitude limit was exceeded
- Correction in a file
- Foundations in Stress Analysis. Question about deviatoric and volumetric strain
- Cant find a resource file of Fluent tutorial guide
1013
945
858
797
