February 6, 2024 at 5:26 pm
Thamanna Iqbal
SubscriberI am doing the FSI analysis of a shell plate passing through an air domain with an initial velocity. Once the run is completed it is showing zero pressure at every state of results for the air domain. Why is it happening so? What can be done to obtain the pressure results for the air domain?
February 8, 2024 at 4:54 am
Ian Do
Ansys EmployeeHi Thamanna,
Pls send a detailed free body diagram (FBD) of the process, (ex: if there is a vel, give its value, etc.). Â
Which method did you use to solve this problem? (ICFD? ALE? ... )Â
Ian Do, PhD
- The topic ‘FSI Analysis’ is closed to new replies.
