March 22, 2024 at 12:49 pm
Prasad Adhav
SubscriberDear sir/ma'am,
I wish to validate results from research papers with ansys model of FRP wrapped RC beam in drop test. The ACP pre meshing requires a surface model to work on. How can I define just the surface if I have to wrap the sheets on the beam? Upon meshing the beam, an error prompt says 'could not find meshing input'. How shall I proceed?
Awaiting reply,
Thank you.
March 26, 2024 at 2:14 pm
Govindan Nagappan
Ansys EmployeeAre you modeling the beam as a solid? You can use the surfaces from the beam. If not, can you post an imae showing the model and provide more details about the model
March 27, 2024 at 4:29 pm
Prasad Adhav
SubscriberHello,
I have shifted to the Explicit dynamics module and I modelled the PEN material wrapping as a solid with thickness. The problem is I am not getting required deflection, 69 mm. Attaching all the details. Can you please tell me which step I am doing wrong? I have modelled the wrapping as simple FRP sheet over the beam instead of patches of 12.5mm, assuming it won't make extraordinary difference.Â
Thanks.
- The topic ‘FRP wrapped beam impact resistance’ is closed to new replies.
