Frictionless support does not detect surface
    • mertturgut.senol
      Dear Experts;
      I am trying to perform an analysis there are two bars and one edge of these two bars are fixed and pressure applied to the bars.
      I created a frictionless support between bar surfaces because they will touch each other. But according to my analysis they pass through each other.
      here is the connection;
      here is the boundary conditions;
      here is the last step which solver could solve.
      where am I making mistake or wrong?
      what can be the reason for this mistake?
      I look forward to your comments and thank you in advance.
      Best regards.
    • ErKo
      Hi
      See our courses in contact for a general overview.
      In your case make sure you have many substeps (https://www.padtinc.com/2011/11/08/you-dont-wanna-step-to-this-breaking-down-loadsteps-and-substeps-in-ansys-mechanical/),
      large deflections on,
      and pinbal region is large enough (see here for info: https://www.padtinc.com/2015/11/09/be-a-pinball-wizard-with-contact-regions-in-ansys-mechanical/).
      Also set displacement scale factor=1.
      All the best
      Erik
    • mertturgut.senol
      Dear Mr Kostson;
      when I applied pinball radius the problem was solved and converged.
      I made not any changes Pinball radius I left it as program controlled.
      thank you for your suggestion.
  • The topic ‘Frictionless support does not detect surface’ is closed to new replies.
