TAGGED: contact-target, contacts, frictional-contact-issues
August 31, 2025 at 11:14 am
turgut.ataseven
SubscriberHi. I want to simulate pin breakage by rotating a part around the vertical axis that is far behind, sinusoidally three times, as shown in the figure. Nonlinear Adaptive Region is defined for pin to simulate breakage accurately. But after defining a Frictional Contact (which always has a status of Open), as orange surfaces being contact and pin surface being target, rotating part just passes through the pin, causing no stress. Inner and outer surfaces should cause stress on pin during every collision. What can I do to perform this analysis?
September 1, 2025 at 5:38 am
Subhash Tadala
Ansys EmployeeHi,Â
Can you check it by increasing the pinball radius to a large value to include both the surfaces ??Â
Also, how you are giving the timesteps in the load step while rotating ? Â
September 1, 2025 at 6:27 am
turgut.ataseven
SubscriberHi,
Submiting large pinball radius unfortunately did not work.
I give sinusoidal Remote Displacement BC of ±3 ºto one of the faces of the rotating body, but instead of smooth sinusoidal curve, displacement curve increases and decreases at a constant rate. How can I imply a sinusoidal movement like one on the right side, instead of one on the left side?
September 1, 2025 at 7:12 am
Subhash Tadala
Ansys EmployeeIncrease the number of displacement points with respect to time/ you can use the function option to define the curve. Also please comment upon the timestepping you are using. Go with good number of substeps/time-steps to make the contact detected.Â
September 1, 2025 at 4:33 pm
peteroznewman
SubscriberWhat is a pim?
September 1, 2025 at 7:27 pm
3827
1389
1188
1100
1015
