May 16, 2024 at 2:55 pm
mohammedlaminemekhalfia
SubscriberDear Ansys experts and users,
Well I am working on a problem where I have two component.
The first is a rotating disk with 100 rpm.
The second is Pin that jus has a friction with a disk and the pin apply a force F on the disk.Â
I am trying to use several force value, but if I used more than 1 N the problem will not be solved due to convergence problem ( I had also penetration issues).
the first thing I did is to adjust the mesh.Â
I applied some of the solutions suggested for different contact problems on changine the for;ulation to normal lagrange and adjusting pinball raduis and change normal stiffness to factor and also adjusting the relaxation damping factor and still I could not manage to solve the problem.
Please advise and thanks a lot for your contibution.
May 17, 2024 at 2:20 pm
Gary_S
Ansys EmployeeIt is often very difficult to apply a Force to close a nonlinear contact gap and achieve convergence.
Try instead using a Displacment. You can then read the resulting Force reaction.Â
- The topic ‘friction between a pin and a rotating disk’ is closed to new replies.
