October 9, 2023 at 10:58 am
paul pladet
SubscriberHello,
A couple of customers are having issues regarding closing of designs in Ansys SpaceClaim. After opening documents and closing them, SpaceClaim freezes and does not repond anymore. The customers have to forcefully close the program and restart it. This problem appeared in the more recent releases of Ansys SpaceClaim.Â
We did a fresh install of Ansys SpaceClaim, but this did not work.
I have received a couple of logfiles from a customer, but i cannot attach them to this post.
Any ideas on what the cause could be? If you need more information, please let me know.
October 9, 2023 at 2:14 pm
dan
SubscriberWe are having the same problem.
October 10, 2023 at 12:58 pm
Roberto
SubscriberI have also reported this problem since the SpaceClaim 2023R1 version was released, there are problems with slow opening of assembly files and crashes.The problem regarding crashes was solved in part (not for all) by carrying out these operations.ÂPlease uninstall SpaceClaim.Then, delete any SpaceClaim folder that exists in C > Program Files.Then, go to the Registry Editor (type Regedit in the Windows search)In HKEY_CURRENT_USER > Software, delete any SpaceClaim folder.In HKEY_LOCAL_MACHINE > Software, delete any SpaceClaim folder.Delete any ansys SpaceClaim folder in C: and AppDataThen, turn off firewalls (including windows firewalls) and antivirus.Then, re-install SpaceClaim. Make sure to run the installer as administrator (right-click run as admin)ÂRegards -
October 10, 2023 at 1:04 pm
Roberto
SubscriberCheck that the PCs have administrator rights
October 10, 2023 at 2:15 pm
dan
SubscriberThanks Roberto,Â
We will give this a try next week when we update to 2023 R2
November 15, 2023 at 4:21 pm
Roberto
SubscriberHelloÂ
I report the continuation of crashes when closing assembly files with a few components, starting from 50 components already
Regards
- The topic ‘Frequent crashes Ansys SpaceClaim after closing documents’ is closed to new replies.
5804
