Frequency response of a beam
    • murali
      Is it possible to obtain the frequency response of a cantilever beam to an initial displacement. Or only time domain results are possible?
    • ErKo
      Hi
      In your initial question you pulled it up (that is what you mean with initial displ. you said) and you release to see the free vibration. That was a transient analysis as it is a transient event (pull and release, followed by free vibration).
      Now if you have a harmonic event like say we move the fixed end of the beam up and down with a sinusoidal displacement then we can use a frequency domain harmonic structural response. We have a course on that, so you can see how it is done.
      All the best
      Erik
      • murali
        Hi Erik,
        Yes I meant the same. Can you please share the link of the course? I would like to know the principles behind adjusting the  analysis settings and other parameters in harmonic analysis. Thanks in advance.
    • ErKo
      Hi
      What do you mean by "I meant the same" - do you mean that you want to excite with a sinusoidal excitation (say displ. or acc., or force)? Please be more clear when describing what you want to do as that will make our feedback back to you better.
      In that case here is a course:
      /courses/index.php/courses/harmonic-analysis-of-structures/
      All the best
      Erik
      • murali
        Yes, i meant introducing a sinusoidal displacement input. Thanks for the link.
        On a different note, is there any way to convert the frequency response thus obtained into time domain?
        • ErKo
          No - that is not possible.
          All the best
          Erik
    • ErKo
      Another course is the msup harmonic:
      /courses/index.php/courses/mode-superposition-method/
      This explains how to set up a base excitation like you might need:
      /forum/forums/topic/base-excitation-harmonic-analysis/
      • murali
        Thanks a lot Erik. I have another question, is it possible to obtain an amplitude-frequency and phase-frequency response from the time domain result of the transient problem?? Like we do in matlab??
    • ErKo
      Hi
      No that is not possible – you can bring it into CFD Post (create a Chart there and use Fourier Transform option),
      or even excel (FFT):
      https://www.youtube.com/watch?v=nbj18E4q1uA
      All the best
      Erik
      • murali
        Ok. Can I use the transient conditions (lifting the free end and releasing it) to conduct a sine sweep in Harmonic analysis? Would it be successfull?
    • ErKo
      Lifting and releasing is not a harmonic sinusoidal load, so of course not - please go through the courses in harmonic analysis to understand this type of analysis.
      Closing this post as we have changed many different topics/questions - open a new one should you have any other questions please.
      Thank you
      Erik
Viewing 5 reply threads
  • The topic ‘Frequency response of a beam’ is closed to new replies.
