Electronics
Electronics
Frequency-dependent permittivity
    • Hamad
      HellonnIs there any way to enter a permittivity that is a function of frequency in HFSS? And how?.Thanks. n
    • rtk
      ,nYes you can enter permittivity as a function of frequency in HFSS.nIn the edit material properties window, select Set frequency dependency and proceed as shown in the snapshot below:nnJust click on the Dataset blank cell to show the drop down menu. By this way either you can import a frequency dependent datasheet or can set frequency points as well.nHope this addressed your concern.nnBest Regards,nn
    • Hamad
      Hello rtk,nnThank you so much. I appreciate your help.Regards,n
  • The topic ‘Frequency-dependent permittivity’ is closed to new replies.
