Fracture Simulation
    • ammorey
      Good morning
      I'm PhD student working on the fracture analysis for semi-elliptical cracks, I'm working on multiple cracks. Actually  finished the modelling and meshing for both body and cracks but when I try to do the analysis from the fracture tool, the  program asking me to choose only one of the cracks ! so I could not finish my analysis.
      The problem which faced me attached bellow  in simple example.. Thank in advance
      Good afternoon,
      Simply insert a Fracture Tool for each semi-elliptical crack.
      Peter
    • ammorey
      Ohhh , I got it .. Thank you so much for your help ..
    • momidor
      May I ask how to select geometry for "Semi-elkiptical carc" ?
      I've model a crack size & shape with radius which I want.
    • ammorey
      hello Momidor,
      simply you have to choose the geometry that you want to insert the crack . For me im not familiar with the version you are using , I use v 19.0
Viewing 4 reply threads
  • The topic ‘Fracture Simulation’ is closed to new replies.
